Español Arabic Chinese (Simplified) croatian Czech Dutch English French German greek Hindi hungarian indonesian italian japanese Korean polish portuguese Romanian russian Swedish
* Note to users who do not speak Spanish. This website is only allowed to write in English or Spanish, messages in other languages ​​will be deleted.
Accent 2005 crdi does not work
More
5 1 months prior week #53508 by  rodrirodriguez77
Accent 2005 crdi does not work Posted by rodrirodriguez77
Good friends
I need help
I have a Accent 2005 CRDI with three pistons
The issue is that he was walking and suddenly stopped and the engine never worked again
I start it and it turns, but as if it had no compression
I already checked that fuel arrives
apply for help
I downloaded the manual but it's not much help
PS: I want to take out the injectors to measure compression but I do not have the torques to reassemble, or a specific disarm guide for injectors.
Any help is welcome
(when there is a problem the mind is blocked)
Please Login o Create Account to join the conversation.
More
5 6 days prior months #53509 by  servilimit
Answer of servilimit about the topic Accent 2005 crdi does not work
Hello rodrirodriguez77.
I have not worked this engine, I have not studied it, but I can tell you that your damage is rare. To begin it is necessary to take out the injectors and test in a bank, if you do not have one near you can do it in the same engine installing it in its same pipe outside of its position and turning the engine, you do not need a special torque to assemble the injectors again or to measure the compression, the arrival of fuel to the injector does not mean that everything is fine, you have to check the pressure and one of them is from the transfer pump and filter outlet. As I say, I do not know that engine, but I hope I could have helped you,
Luck
More
4 1 months prior week #53699 by  armando1890
Answer of armando1890 about the topic Accent 2005 crdi does not work
I do not coke your engine but that kind of problems occur when the band or chain of synchronization breaks, many times it is enough to remove the oil plug or the front cover of the band to start and see if it rotates the camshaft.
Search MDM
Groups shared manuals
210 MANUALS
127 MANUALS
136 MANUALS
64 MANUALS
MDM Activities
john y 6824 other you have joined the group Workshop Manuals Heavy Vehicle 7 hours 51 minutes
Alejandro Hill y 20215 other you have joined the group Car Workshop Manuals 10 hours 16 minutes
Juancho Tomasini y 9242 other you have joined the group Motorcycle Workshop Manuals 12 hours 27 minutes
Cookies on this site are used to personalize content and ads, to provide social networking features and analyze traffic. We also share information about your use of the website with our partners social networking, advertising and web analytics who can combine it with other information provided to them or they have gathered from the use made of its services. To change the settings or more information click on the "More Info".
